Post by 180°off on Mar 16, 2016 1:24:21 GMT -5
Took my scoot out for a ride today. Going good at wot, but when I was having to slow down the engine stoped on me.had to push it to the side and kick started it. Started back up? It's the 3rd time this has happened? Also a bad voltage regulator would make it so none of my electronics work right? Like lights and instrament panel?
Post by mclark999 on Mar 16, 2016 14:13:06 GMT -5
Mine does that when it's running lean.
Post by 180°off on Mar 16, 2016 15:53:18 GMT -5
Does it make a whining sound also?
Post by thatcrazyguy on Mar 16, 2016 20:51:14 GMT -5
Does it make a whining sound also? Sounds like your experiencing soft seizes, upjett!
Post by Clank on Mar 17, 2016 1:48:43 GMT -5
4pokes do that too but it's usually valves.
Post by 180°off on Mar 17, 2016 16:35:35 GMT -5
Well I took the piston out and thank god I did because it was about to fail on me big time. Guess I will be ordering a new jet soon. Any ideas on what size I should get?
Post by thatcrazyguy on Mar 17, 2016 17:03:15 GMT -5
Well I took the piston out and thank god I did because it was about to fail on me big time. Guess I will be ordering a new jet soon. Any ideas on what size I should get? I advise you to just get a whole kit that includes 10+/- jets, start high. Is this a 70cc? What size carb and are you using stock airbox or open filter?
Post by 180°off on Mar 17, 2016 19:21:05 GMT -5
No I got a stock 50 but will probably move up to a 70 since all I need is a piston and rings. Stock airbox but I have a tuned pipe on it. Nothin fancy, a 99 dollar ebay one that someone gave me thankfully.
Post by thatcrazyguy on Mar 17, 2016 19:38:18 GMT -5
No I got a stock 50 but will probably move up to a 70 since all I need is a piston and rings. Stock airbox but I have a tuned pipe on it. Nothin fancy, a 99 dollar ebay one that someone gave me thankfully. If start from 100 and work down from there. 100 will probably be too rich but it's always safe to start high and work down so you don't blow your top end!
