Post by renagade281 on Apr 17, 2016 11:00:27 GMT -5
Did the compression test and only got about 85psi so I put about a teaspoon of oil down the spark plug hole and did it again and it jumped up to 200psi. Does that mean my piston rings are bad ?
Post by renagade281 on Apr 17, 2016 11:37:39 GMT -5
yea what i said above ^^^
Post by scott7 on Apr 17, 2016 13:51:58 GMT -5
Lol
Post by 90GTVert on Apr 17, 2016 20:25:45 GMT -5
Most likely the rings are bad. You may have added too much oil. 85 to 200psi is a lot. Either way, I'd tera it down and have a look.
Post by renagade281 on Apr 18, 2016 8:02:14 GMT -5
Most likely the rings are bad. You may have added too much oil. 85 to 200psi is a lot. Either way, I'd tera it down and have a look. Either way I'm gonna put a bbk on it
