Post by renagade281 on May 6, 2016 21:14:34 GMT -5
can i just cut the stock springs to lower it? i have every tool at my fingertips, i just dont wanna have to order a lowering bracket or new springs... is there any way to lower the rear without ordering anything?
Post by dude on May 6, 2016 22:17:43 GMT -5
Some shocks unscrew at the bottom. It loaded with pressure be careful. But then you lose that inch and half travel you had. Find a shorter shock.
Post by frank50e on May 7, 2016 10:12:13 GMT -5
I gotta agree with Dude cutting a shock springs not a good idea.You don't have to spend a bunch just find a shorter shock that will "slam it down" for you.
Post by Clank on May 9, 2016 2:34:23 GMT -5
You got everything at your fingertips, then relocate your upper shock mount to a higher position.
