Post by renagade281 on May 8, 2016 21:22:29 GMT -5
So after i installed this i noticed alot of vibration (so bad that u can hear it if u hit a big dip in the road) when i would hit bumps. Maybe i should have welded the brace to the part im pointing at instead of where it is? Its not a hard fix if so. Any suggestions? I never had this vibrating issue before i installed this. And the only other modification i did that same night was the a9 cam and i know that has nothing to do with it
Post by 90GTVert on May 8, 2016 21:40:10 GMT -5
Yeah, you should attach to the frame. The engine mount I'd imagine would transmit a lot of vibes.
Post by renagade281 on May 8, 2016 21:55:19 GMT -5
That was def my issue. I just cut it off at the bottom and took it for a test ride and no vibration at all. Im gonna weld it to the other part of the frame and see how that goes
Post by renagade281 on May 8, 2016 21:56:40 GMT -5
Yeah, you should attach to the frame. The engine mount I'd imagine would transmit a lot of vibes. Maybe you should add that to your write up in the tech section so dummys like me dont get confused lmao. Good call brent
Post by jkeney on May 9, 2016 12:52:20 GMT -5
I can't imagine how much your scoot hated having that bar on the motor mount. Glad you got it sorted.
Post by jkeney on May 9, 2016 12:53:27 GMT -5
I am dying to do this mod on my bikes too. Just waiting for a reason from house president to buy a welder.
Post by renagade281 on May 9, 2016 13:46:03 GMT -5
I can't imagine how much your scoot hated having that bar on the motor mount. Glad you got it sorted. yea i kept wondering why everytime i would hit a dip in the road it would vibrate to the point of almost feeling like something was grinding... its all better now... feels great
Post by frank50e on May 9, 2016 16:42:43 GMT -5
Did you consider letting your significant other ride the bike befor repairing the problem,just sayin moms day and all.
Post by 2stroked on May 9, 2016 17:32:12 GMT -5
Did you consider letting your significant other ride the bike befor repairing the problem,just sayin moms day and all. LOL!!!!! !!!!! ROFLMFAO Too much man!
Post by renagade281 on May 9, 2016 18:50:55 GMT -5
Did you consider letting your significant other ride the bike befor repairing the problem,just sayin moms day and all. [9br] Lmfao. That's classic. But unfortunately she's in South Carolina
Post by FrankenMech on May 9, 2016 21:11:48 GMT -5
I am dying to do this mod on my bikes too. Just waiting for a reason from house president to buy a welder. Just get a frame-looking type part, saw it part way through, then bust it. Show her the part, don't let her get a real good look at it. Then tell her you are going to the store because you need a welder! When you get back practice welding the piece. When you get your first booger weld done show it to her with pride!
Post by renagade281 on May 9, 2016 21:51:19 GMT -5
I am dying to do this mod on my bikes too. Just waiting for a reason from house president to buy a welder. Just get a frame-looking type part, saw it part way through, then bust it. Show her the part, don't let her get a real good look at it. Then tell her you are going to the store because you need a welder! When you get back practice welding the piece. When you get your first booger weld done show it to her with pride! Good call
