Post by stephen97 on May 27, 2016 12:49:44 GMT -5
My bike seems to stay in too high of a gear when trying to go up small inclines and loses all power. Any ideas? Its a pulse scout 49 2014
Post by niz76 on May 27, 2016 17:54:34 GMT -5
Post by stephen97 on May 27, 2016 18:28:54 GMT -5
I have new lighter roller weights to go in aswell. Would they help any?
Post by niz76 on May 27, 2016 19:43:05 GMT -5
rollers need to be tuned to your liking when changing torque spring. Typically a heavier torque spring needs heavier rollers to counteract it.
Post by dan50 on May 27, 2016 19:52:26 GMT -5
The contra springs wear out from heat stress, this is an issue on one of my scoots.
Change the contra spring, if you have a stock motor, try a 1,500 pound spring (1,000 pound is stock), then mess with the rollers to match.
Post by stepthrutuner on May 27, 2016 19:55:28 GMT -5
Also dissambly and relube of your torque driver pulley could help it's movement.
Post by just1artist on May 28, 2016 1:04:26 GMT -5
Do the 3 guides slide smoothly in the variator? Flat spots on the rollers?
