Post by floyd2133 on Jun 16, 2016 14:49:33 GMT -5
ok and f it gets significantly harder to turn when it gets close to top dead center what does that mean
Post by floyd2133 on Jun 16, 2016 14:52:24 GMT -5
Post by arkie on Jun 16, 2016 14:53:23 GMT -5
It means that you have at least some compression. And don't be fooled by the magnetism of the flywheel. you will feel that at various places. the compression will or at least should feel stronger.
Post by arkie on Jun 16, 2016 14:56:45 GMT -5
Sorry I could not hear compression in your vids. That doesn't mean that you don't have any just that you still need to check by hand.
Post by Deleted on Jun 16, 2016 14:57:55 GMT -5
ok and f it gets significantly harder to turn when it gets close to top dead center what does that mean It means you have at least some compression. To run you need fuel/air in the right mixture, spark and compression. You are trying to test each of these to see which one you are missing. This is the basic compression check without a gauge. If you have all three things it will start and run.
Bill
Post by floyd2133 on Jun 21, 2016 19:23:44 GMT -5
I took it to the shop he simply put his hand on the back of carb. N kick started it. Then gave me a new carb
