Post by arkie on Jun 20, 2016 21:11:19 GMT -5
The fan is usually white plastic and its got a cover,black. in the pic you have the top shroud. you need it the bottom shroud the fan and the cover or you will cook your engine.
Post by spaz12 on Jun 20, 2016 21:12:09 GMT -5
what is a main jet . they just took it out the box n installed it because the one day put on the day before was bad it's a brand new carb 2 days old national I been riding it since Sunday. it booked out on me n shut down for 3 min but crank back up after kicking n push start It probably soft seized on you. The piston got so hot and expanded and stuck to the sides of the cylinder. You probably won't be so lucky next time.
Post by floyd2133 on Jun 20, 2016 21:14:02 GMT -5
so this isn't a fan or a shroud either. and why didn't my bike come with one of its needed it
Post by spaz12 on Jun 20, 2016 21:14:52 GMT -5
Main jet is a fuel metering device that can be changed for bigger or smaller one's depending on what the motor needs. Whatever came stock inside the carburetor is surely not big enough to handle a bigger bore and the open type filter you are using.
Post by arkie on Jun 20, 2016 21:16:47 GMT -5
Yeah thats the fan and the fan cover. I saw the top shroud so all I havent seen is the bottom shroud and the rubber gasket that goes around the head.
Post by spaz12 on Jun 20, 2016 21:17:24 GMT -5
so this isn't a fan or a shroud either. and why didn't my bike come with one of its needed it So now you have two parts of the shroud. You are missing the bottom half that goes around the cylinder. You need them all. No idea why it didn't come with one. Guarantee you though, with out any doubt, that it NEEDS to be there.
Post by floyd2133 on Jun 20, 2016 21:17:39 GMT -5
ok but what you described is a fan shrouds correct and the dude told me it's a 20 sum carburetor. I'm boutique to run the bickering idle to see if the leak stops. thanks a lot bro
Post by arkie on Jun 20, 2016 21:19:18 GMT -5
The bad news is to put the shroud on you must take off the exhaust and the intake. The good news is if you put it on you wont fry your new engine.
Post by floyd2133 on Jun 20, 2016 21:19:18 GMT -5
ok but I feel like the fan is most important is the bottom half the plastic piece I showed up earlier. I asked the mechanic they act if it was a big deal long assume the other parts were on
Post by floyd2133 on Jun 20, 2016 21:25:06 GMT -5
ok so tomorrow I will take it to the mechanic and Tell him to put this price on . finally anything else I need.
Post by arkie on Jun 20, 2016 21:27:03 GMT -5
Just the bottom of that piece and the rubber gasket that goes around the head.
Post by floyd2133 on Jun 20, 2016 21:30:58 GMT -5
I'm not leaking any oil thanks just got to get my shrouds. if anybody else have suggestions feel free to comment
Post by floyd2133 on Jun 20, 2016 21:39:02 GMT -5
actually now I'm spitting out oil
Post by floyd2133 on Jun 20, 2016 21:40:18 GMT -5
Post by arkie on Jun 20, 2016 21:55:11 GMT -5
It needs to drain back into the cover. after it sits a while or you remove the hose and drain what oil is in it it will be fine. the problem was you had it maybe 1/4 full of oil. the pressure of it running will blow it out. but after cleaning it what comes out will just be vapor and what condenses in the hose will drip back into the cover.
