Post by floyd2133 on Jun 22, 2016 13:35:54 GMT -5
larm stop working after battery died. recharged battery by riding. It push starts now but every time i push the remote my bike jus clicks and the fuel guage pops to full to empty
WEAscoot
"Preventative" Maintainance
Post by WEAscoot on Jun 22, 2016 13:55:01 GMT -5
Check fuses and relays. There's probably a fuse on the security system, and there's one next to your battery. Does the regular starter work?
Edit: Just need you to clarify what you mean by "push start," since I think of popping the clutch on a motorcycle to start it when I think of "push starting"
Also, do you have a battery charger/tender? A multimeter? Riding it may not have gotten its charge up enough... Also make sure all your lights are off, that'll reduce draw when trying to start.
Post by floyd2133 on Jun 22, 2016 14:40:46 GMT -5
push start on the bike works(regular start) however the remote push doesnt work it is a lock/unlock/remote start alarm. all it does is click. no i dont have a charger but i will take it to autozone. and the battery is 3 days old
WEAscoot
Post by WEAscoot on Jun 22, 2016 15:19:07 GMT -5
Shouldn't be the battery then, and it clicks? Like one click? YouTube: How a relay worksCheck that all the wires for the security system are in their sockets snugly. If its clicking it means the unit is receiving the signal and triggering the relay to try to start the bike, but after that there's a problem. Either a wire is loose/broke/burned or a kill switch of some sort is "on" When you start it from the bike do you change anything from when you try the remote starter? Keys or thumb switch?
Post by floyd2133 on Jul 8, 2016 20:19:35 GMT -5
Shrouds on. Wrong ven number plate. Bent mirror. After fr I m coming from shop. I Owe 47$ Remote Alarm Not Working or Remote Start. They told ne shrouds dont come on Taotaos witch resulted in the 67 fee not to mention the 50 dollar toe to the shop last week. I have them 20 n hauled iff with my scooter today. They didnt act kike they wanted to trust me with 47 i owrd after i spent 400 upgrade and 50 for towe. Scotter bigged out after hour of driving and immediately after gas station. Shiuld i not go to the local arabian petro premium gas station? After a 10 min cool down and plenty starter fluid aimed at the high performance air filter and hella revving it starts. Fine but why doesnt my alarm work the mechanic check the ground. It is fine. It clicks like it wants to work but nothing happens. However the e goes to f on the fuel gauge. Also if the remote start is pushed. You can take the key out n it stills run. So it works undercover but no alrm sound nor turn over engine with remote start. Happy All On One Post Read more: 49ccscoot.proboards.com/thread/16271/ran-out-gas-iver-mph#ixzz4Ds0NpPI4 Also the dummies left out the hose to the valve cap now oil is splirting everywhere. Is tha a major issue? Read more: 49ccscoot.proboards.com/thread/16271/ran-out-gas-iver-mph#ixzz4Ds0Q9tPS
Post by gsx600racer on Jul 17, 2016 0:02:32 GMT -5
I was bored today and decided to dig out the Keeway. Of course the battery was dead from sitting for a month or so(alarm system drained battery) So I hooked up the battery charger and charged it for a couple hours on 2 amps.
Here is the end results.
As you can see, other than waiting for a couple hours, the dead battery did no harm to the alarm/remote start system.
