Post by floyd2133 on Jul 9, 2016 20:29:56 GMT -5
Does 2015 tao tao 50 cc come with shrouds
Post by just1artist on Jul 9, 2016 20:35:30 GMT -5
Engine shrouds? If that is the question then, YES YES YES!!! If you don't have the cooling shrouds on then I strongly suggest NOT running scooter! It WILL overheat! Heat is bad... Running without will drastically reduce engine life...
Post by gsx600racer on Jul 9, 2016 21:52:46 GMT -5
From tao tao parts direct.I see shrouds. Where you had the work done, do they sell new scooters ? If so check to see if they have engine shrouds, or check online.(if you still have doubts)
Post by eclark5483 on Jul 10, 2016 0:15:38 GMT -5
Post by Deleted on Jul 10, 2016 13:45:39 GMT -5
Post by iwannascoot on Jul 10, 2016 17:42:13 GMT -5
Does 2015 tao tao 50 cc come with shrouds YES! Again, and again, and again you were told you needed shrouds. Your scoot was built with shrouds and your mechanic told you you didn't need them so you drove it without shrouds. I told you to sue your mechanic but you took it back and paid them to put your shrouds back on. This has been a disaster since your first post. Now you have paid them even more and your scoot still won't run. I'm really sorry for what has happened with all this and hope you end up with a running scoot soon. If you ever manage to get this running your next problem is likely to be a broken crankshaft. The nearly unanimous opinion of the forum members here is that a 100cc BBK will not last very long. The 47mm 80cc BBK is much more likely to last over a couple thousand miles. A crankshaft replacement is a pretty major job and you will likely have to pay someone to do that for you. I surprised you actually asked this after the number of times you were told you needed the shrouds. It seems to me you do not trust the advise you have received on this forum. Billy
Post by 90GTVert on Jul 10, 2016 17:46:08 GMT -5
Here's some reassurance for you. The Q in 139QMB or 1P39QMB, designates that the engine is forced air cooled. That means it has a fan. A fan does no good without the shrouds. So once again, yes, it came with them or it should have.
