Post by badpumpkin on Jul 14, 2016 19:40:10 GMT -5
I have stock tao tao 49cc, stock carb with 16,30 jets, I replaced it with keihin 18mm 33 ,85 it won't run.Do I down the jet size,
Post by arkie on Jul 14, 2016 19:54:58 GMT -5
You can try the stock jets in the keihin carb. Should be close. But I don't quite understand when you say they are 16,30
Post by arkie on Jul 14, 2016 19:59:35 GMT -5
30,76 maybe?
Post by badpumpkin on Jul 14, 2016 20:00:27 GMT -5
The jets in the tao tao carb are imprinted with 16,30,What do you think, does china have a different jet measure system
Post by arkie on Jul 14, 2016 20:25:43 GMT -5
IDK. But you can try them and see if it works. If not you will need to order jets for your new carb and then do a tuning process.
Post by mclark999 on Jul 14, 2016 20:32:48 GMT -5
Try choking it by covering the intake with your hand. If it starts then it's probably too lean.
Post by badpumpkin on Jul 15, 2016 21:37:25 GMT -5
Hey, I put the keihin with 33,85 jets back on/in, I pulled off performance wire and coil and put coil on plug unit on....its alive!!!! I put 10 miles on tonight and this is after it not running for a week, I think c.o.p.s are the way to go!
