Post by floyd2133 on Aug 9, 2016 21:35:20 GMT -5
Post by floyd2133 on Aug 9, 2016 21:36:03 GMT -5
Post by floyd2133 on Aug 9, 2016 21:43:31 GMT -5
I think my spring has aunt hung to do with it . It keeps overlapping and piping the gear off when I test it after a few tries.
Post by floyd2133 on Aug 9, 2016 21:59:27 GMT -5
Post by floyd2133 on Aug 9, 2016 22:09:18 GMT -5
Post by floyd2133 on Aug 9, 2016 22:32:57 GMT -5
Post by stoneforth on Aug 9, 2016 22:50:13 GMT -5
Post by floyd2133 on Aug 9, 2016 23:45:18 GMT -5
Ya I got it to crank once but then it got stuck all the way down. I'm having putting on the washer and the horseshoe lock together so I tried it without the washer just the horse lock. N it cranked but gear got stuck at bottom
Post by 90GTVert on Aug 10, 2016 15:09:09 GMT -5
It looks like the spring may be a bit out of place from some of the pics. Look at 3:30 in the vid. Also, make sure everything can move smoothly. If that smaller gear binds up in the case, it causes return issues.
Post by floyd2133 on Aug 11, 2016 0:26:36 GMT -5
I got it on but working in the dark I put the same shaft gear on it . Witch I wasted my time now I have to do it over again n just switch out the half moon shaft gear for the new one . I messed up smh at least it cranks n works tho.
Post by Fat_Panda on Aug 11, 2016 11:58:30 GMT -5
i broke the tab on the case that stops the half sprocket yesterday i feel your pain dude
Post by stoneforth on Aug 12, 2016 17:06:32 GMT -5
i broke the tab on the case that stops the half sprocket yesterday i feel your pain dude can you use a bolt instead
Post by Fat_Panda on Aug 12, 2016 17:30:59 GMT -5
i broke the tab on the case that stops the half sprocket yesterday i feel your pain dude can you use a bolt instead yeah i was thinking of tapping in a bolt or something along those lines funny enough i lubed it up and it helped a ton.
Post by floyd2133 on Aug 12, 2016 20:40:09 GMT -5
Ok I got that problem fixed however my kick lever is stripped. Any suggestions?
Post by floyd2133 on Aug 13, 2016 9:14:54 GMT -5
