Post by stancejontland on Aug 25, 2016 10:32:13 GMT -5
Hey guys need some help with taking off my front wheel from my scoot it has some abs braking system.
Post by humanshield on Aug 25, 2016 11:57:59 GMT -5
I don't see any sensors so what makes you think it has ABS?
ABS requires a computer to control it. I seriously doubt you have an ABS system on your scooter.
Just unbolt the axle, yank it out and take the wheel off. Done.
phatmanxxl
Post by phatmanxxl on Aug 25, 2016 12:15:21 GMT -5
Post by stancejontland on Aug 25, 2016 12:16:13 GMT -5
It has abs the computer is under my headlights. So just take the 2 bolts out the caliper and the axle nut ?
Post by stancejontland on Aug 25, 2016 12:20:40 GMT -5
So don't even bother with the caliper just the axle nut
Post by 90GTVert on Aug 25, 2016 12:32:02 GMT -5
Usually you can just remove the axle nut and the axle and slide the wheel out without needing to mess with the brakes.
ABS on these scoots is generally nothing more than a pressure limiter. No computer control or anything fancy and generally debatable if it accomplishes much.
Post by humanshield on Aug 25, 2016 12:34:13 GMT -5
Yes...the post above... ^^^^
Post by gsx600racer on Aug 25, 2016 13:05:39 GMT -5
Maybe the ABS he seen stood for "Acrylonitrile Butadiene Styrene" which a lot of plastic parts are stamped with.
Just saying.
Post by fts902 on Aug 25, 2016 14:25:05 GMT -5
Maybe the ABS he seen stood for "Acrylonitrile Butadiene Styrene" which a lot of plastic parts are stamped with. Just saying. This is more likely.
Post by niz76 on Aug 25, 2016 17:38:19 GMT -5
The Chinese often install those pressure limiter thingy's as Brent pointed out, and then label them as "ABS". So yes, many scoots have stickers or whatnot that says it has ABS braking but it's not truly ABS braking- typical Chinese marketing! haha
larrball
2016 Genuine Scooter Rough House Sport Ti
Post by larrball on Aug 25, 2016 20:34:51 GMT -5
like everyone said --Not really ABS. YOU are the ABS. And even if one could put a true abs on a scooter, the light weight on the frount end would not help much, one small sand/rock/oil or water pile and you need to stop NOW..... and you'r down for the count. Been there done that. Thank's Icon. Icon Overlord Textile Jacket
Post by stancejontland on Aug 26, 2016 11:45:56 GMT -5
I removed my wheel and tire to check for bad wear or messed up parts everything seems ok. What else could cause my wheel wobbling back and forth around 30 mph but goes away after 35
