Post by ewasleske on Sept 2, 2016 17:31:04 GMT -5
I was perusing Craigslist.org and came across a couple of four stroke Tritons. I was under the impression that they only came in a two stroke model. Are these aftermarket changes or did the factory build a 4T?
Post by niz76 on Sept 2, 2016 18:48:50 GMT -5
Most of the China model scoots are available in 2t and 4t like that. Wouldn't surprise me if there's an electric version with that body style also...
Post by ewasleske on Sept 3, 2016 14:49:43 GMT -5
Would a swap to a two stroke be easy or are the engine mounts different?
Post by 90GTVert on Sept 3, 2016 15:17:49 GMT -5
Tritons were only 2Ts till later in their run.
The 139QMB and 1E40QMB definitely use a different mounting setup, so the only way it's an easy swap is if the frames are equipped for either. I wouldn't count on that being the case.
Post by ewasleske on Sept 4, 2016 20:43:25 GMT -5
I was considering a Triton as a parts bike until I noticed it was a 4t. Makes it less desirable since mines a 2t.
Post by maker1to2 on Oct 8, 2016 23:53:18 GMT -5
