Post by floyd2133 on Sept 9, 2016 11:24:27 GMT -5
Any thoughts?
Post by floyd2133 on Sept 9, 2016 11:25:54 GMT -5
Post by floyd2133 on Sept 9, 2016 14:15:12 GMT -5
Will it not crank without help of a drive belt or no ?
Post by humanshield on Sept 9, 2016 15:00:11 GMT -5
This is a table of the actual resulting displacement in cc's you will get with a stock 41.5mm crank and the listed piston. The figures are rounded to the nearest CC.
The cc numers listed in ads on ebay and elsewhere are not correct. A 50mm BBK will not give you 100cc's
39mm stock = 50cc 47mm BBK = 72cc 50mm BBK = 81cc 52mm BBK = 88cc
Post by humanshield on Sept 9, 2016 15:01:31 GMT -5
Will it not crank without help of a drive belt or no ? It will start without a drive belt. If the cover is off....You just need to rig the solenoid so that it engages. If the cover is on it will start without a drive belt.
Post by floyd2133 on Sept 10, 2016 15:00:26 GMT -5
I got it to start but it won't idle
Post by floyd2133 on Sept 10, 2016 18:22:00 GMT -5
