Post by badpumpkin on Sept 7, 2016 20:20:27 GMT -5
Does anyone have experience with these , or where to get parts. I need a cylinder, rings and piston kit. I have a 2007 Lance Vintage with 10.5 inch wheels .
Post by humanshield on Sept 7, 2016 20:37:23 GMT -5
I had a hell of a time getting top end parts for my 150 when I was rebuilding the engine. Seems there are a lot of different heads, bolt patterns, deck heights etc.
Much harder than doing a 50 cc scoot where most are the same.
Post by badpumpkin on Sept 7, 2016 21:00:25 GMT -5
No kidding, all I've read is be careful what one purchases. I plan on spending a bit of time on the phone.
Post by humanshield on Sept 7, 2016 21:21:06 GMT -5
Very good advice. I ended up buying three cylinder heads that would not fit. I ended up rebuilding the one I had.
Post by tortoise2 on Sept 7, 2016 21:27:33 GMT -5
Post by humanshield on Sept 7, 2016 21:30:56 GMT -5
"Should" be. Correct. Until you start ordering and find out you don't get what you ordered many times A lot of the problems come from the other end.
Post by badpumpkin on Oct 5, 2016 18:46:51 GMT -5
I got parts from parts for scooters and fit perfect. I did micrometer every aspect of the cylinder and piston. Started first time.
