Post by renagade281 on Sept 17, 2016 10:45:41 GMT -5
when removing the rocker arms, one of the cylinder studs came out with the nut. it is not stripped and will screw right back in but my question is how do i properly tighten it?
AG
Post by AG on Sept 17, 2016 10:48:49 GMT -5
Put two nuts on it and tighten the top one. It will screw the stud back in.
Post by renagade281 on Sept 17, 2016 10:49:59 GMT -5
good call !!!
Post by humanshield on Sept 17, 2016 12:20:16 GMT -5
But also get some red loctite and secure it so that it can not loosen again.
Engine studs should not vibrate loose or be easily removed. They need to be very secure at all times.
