Post by renagade281 on Sept 17, 2016 10:49:32 GMT -5
when removing the rocker arms, one of the cylinder studs came out with the nut. it is not stripped and will screw right back in but my question is how do i properly tighten it?
EDIT: i moved it here because i need a quick answer so i can put this thing back together
Post by ThomasTPFL on Sept 17, 2016 12:53:50 GMT -5
Two nuts tightened against each other on the stud, run it in, use two wrenches to break the nuts loose so you don't just unscrew the stud.
Post by dan50 on Sept 17, 2016 20:34:08 GMT -5
Two nuts tightened against each other on the stud, run it in, use two wrenches to break the nuts loose so you don't just unscrew the stud. That's an easy solution that I wouldn't have thought of. Great idea!
