mclendine
Scoot Junior
Post by mclendine on Sept 23, 2016 9:17:57 GMT -5
I have a zummer 49cc scooter with all most everything done to it 100 kit big valve head 21mm carb race variator but I was wondering if a GY6150 motor would bolt right up to it or would I have to do a bunch of fab work to make it work
Post by tortoise2 on Sept 23, 2016 9:25:11 GMT -5
Post by Deleted on Sept 23, 2016 9:41:44 GMT -5
I have a zummer 49cc scooter with all most everything done to it 100 kit big valve head 21mm carb race variator but I was wondering if a GY6150 motor would bolt right up to it or would I have to do a bunch of fab work to make it work It can be done and has been done. There are some topics on here about it somewhere. (try the search feature) But, yes, you do have to be able to weld and a lot of fabrication has to be done because, and I always get confused about which is which, one of the engines is a top mount and the other is a bottom mount. Bill
phatmanxxl
Post by phatmanxxl on Sept 23, 2016 9:42:33 GMT -5
Short answer no.
Long answer, a lot of welding and a conversion kit it can be done.
Post by dan50 on Sept 23, 2016 11:53:54 GMT -5
Post by stoneforth on Sept 23, 2016 12:00:13 GMT -5
After seeing the quality of the frames, and having to reweld an engine mount because the steel tube tore around the weld; i wouldn't want to be going too fast on it without strengthening the entire thing first.
Post by Deleted on Sept 23, 2016 12:02:42 GMT -5
I have a zummer 49cc scooter with all most everything done to it 100 kit big valve head 21mm carb race variator but I was wondering if a GY6150 motor would bolt right up to it or would I have to do a bunch of fab work to make it work I think you know what you are doing by now
phatmanxxl
Post by phatmanxxl on Sept 23, 2016 13:00:17 GMT -5
I was looking for that, couldn't find it.
mclendine
Scoot Junior
Post by mclendine on Sept 23, 2016 13:16:03 GMT -5
Yeah I was wondering because there's a scooter shop by me and he was telling there was a 150 that was the same and would bolt right up
Post by Deleted on Sept 23, 2016 16:00:10 GMT -5
Post by tortoise2 on Sept 23, 2016 16:15:37 GMT -5
Typical GY6 125/150 has top mounts. Exceptions include a motorcycle style variation and Sym/Lance engines.
Post by Deleted on Sept 23, 2016 17:17:11 GMT -5
Nice they have a pre made one but, it says for 8" or 7" wheels...is there any for 10" wheels? Bill
Post by gsx600racer on Sept 23, 2016 18:16:40 GMT -5
Its been done, If you have the pockets(cash), time, tools, and the skills to take on this type of project, then by all means go for it.
This type of swap is really popular in the stretched Honda Ruckus scene.
Post by joeorange on Oct 10, 2016 20:55:37 GMT -5
A gy6 150 swap is rather easy, ive do one, went back to my 2 stroke and i am going back to the gy6 again. as long as you have all the parts needed for the swap, including engine, carb, exhaust, wiring, wheel, brake shoes and engine mount. and if you have a welder, you can have it done in under 4 hours.
now my swap was from a 1e40qmb 2 stroke to the gy6 and was easy for me. but since i havent worked with the 139qmb frame i couldnt tell you much, but youll have to either weld the gy6 150 engine mount to the frame solid, or if you want the keep the mount bushings then youll have to fab up some frame tabs for the engine mount.
also with the frame tabs, it will allow you to keep the stock 139qmb mounting points and you can switch back to the smaller engine if you ever needed to.
also if you do the 150 swap, make sure you have the wheel aligned properly to the front one, also there is a chance that your stock shock mount wont align as well, so you may have to either move it, or make another one and weld it to the frame.
i hope this helps a little.
Post by FrankenMech on Oct 10, 2016 22:42:46 GMT -5
Nice they have a pre made one but, it says for 8" or 7" wheels...is there any for 10" wheels? Bill I think they mean 7 or 8" wide wheels, but I may be wrong as usual. I need to do the 50cc to 125cc conversion myself. I won't be doing any welding, just brazing.
