phatmanxxl
Post by phatmanxxl on Sept 24, 2016 12:00:58 GMT -5
Thoughts on using red high temp gasket sealer on the exhaust pipe? I crushed the copper ring and now I'm back firing.
Post by tortoise2 on Sept 24, 2016 12:12:31 GMT -5
Post by just1artist on Sept 24, 2016 12:23:19 GMT -5
Auto parts stores carry exhaust gasket material... I just cut out my template from that (usually) lol at the moment my gasket is made from jeep exhaust manifold gasket...
phatmanxxl
Post by phatmanxxl on Sept 24, 2016 14:05:11 GMT -5
Auto parts stores carry exhaust gasket material... I just cut out my template from that (usually) lol at the moment my gasket is made from jeep exhaust manifold gasket... Link?
Post by just1artist on Sept 24, 2016 14:15:58 GMT -5
Post by renagade281 on Sept 24, 2016 16:01:38 GMT -5
I wonder if that's why my exhaust is backfiring like crazy lol
phatmanxxl
Post by phatmanxxl on Sept 24, 2016 17:04:16 GMT -5
I wonder if that's why my exhaust is backfiring like crazy lol Probably, or bad compression.
Post by renagade281 on Sept 24, 2016 19:11:50 GMT -5
Compression is at around 160-170
Post by gsx600racer on Sept 24, 2016 21:42:43 GMT -5
In a pinch, some gaskets for small engine's(briggs n stratton, kohler, ect) will almost be an exact fit.
Post by ryan_ott on Sept 24, 2016 21:54:55 GMT -5
That's where all of mine come from. ^^^
Post by renagade281 on Sept 25, 2016 1:45:17 GMT -5
Do y'all prefer the ring or the gasket with the bolt holes in it? I would like to get the best gasket I can get so I dont have to keep replacing them. I had the ring on it and it seemed like it just melted
Post by Clank on Sept 25, 2016 3:02:00 GMT -5
You need to clean all surface mounting areas of header to head thoroughly. If you use the property squish gasket you shouldn't need any fake gasket seal. BUT.... This is if your in a pinch, Copper RVT gasket sealer would be your best bet. BUT..... And again I use this term loosely, use lightly. More is not always better.
phatmanxxl
Post by phatmanxxl on Sept 25, 2016 9:00:17 GMT -5
There is a local owned auto parts store with the B&S exhaust gaskets but they aren't open on the weekends. Its the only place in town that I've seen them sold at. It looks like it would fit the scoot. I went to Autozone and O'Reillys looking for that Mr.Gasket thing but nobody carried it. I put the red RTV gasket sealer around it just to use today and I'll pick up that B&S gasket tomorrow and she how that goes until I can get get something shipped in. I'll probably order a handful of these:
Post by FrankenMech on Sept 25, 2016 14:38:14 GMT -5
I like those metal faced gaskets. I buy mine from TVnACman.
Teflon is not a good exhaust gasket material. When Teflon is heated it releases PFOA gas which is more toxic than Phosgene gas.
