Post by gsx600racer on Oct 9, 2016 17:46:19 GMT -5
Sorry my mistake again 😬 No worries. Not to scare ya but this could be a possibility with a battery with the wrong charger. Lithium and LIpo batterys have the same guts inside. The fact you are doing this in your living room, I would take caution.
Post by floyd2133 on Oct 10, 2016 0:58:17 GMT -5
Starter solienoid is clicking now after new bendix n bushing installed Video here youtu.be/m_aqalqVHnI
Post by gsx600racer on Oct 10, 2016 2:54:53 GMT -5
you cooked your starter or a bad ground
Post by floyd2133 on Oct 10, 2016 8:06:52 GMT -5
I jus bought this starter 2 days ago
Post by floyd2133 on Oct 10, 2016 8:13:40 GMT -5
And I tried my other starter it's doin the same thing...I think it's the solienoid
Post by gsx600racer on Oct 10, 2016 9:05:13 GMT -5
Weii if that was the case, the starter would of spun when you used the screwdriver in the last video.
Post by floyd2133 on Oct 10, 2016 9:11:50 GMT -5
Weii if that was the case, the starter would of spun when you used the screwdriver in the last video. I just hooked my old starter up bridge the connections and no spinning
Post by gsx600racer on Oct 10, 2016 12:24:42 GMT -5
You do realize when you bridge the connection, you eliminate the solenoid from the picture. So its either a low battery, bad starter, the larger red wires are bad, or loose ground connection.
Post by floyd2133 on Oct 10, 2016 12:30:48 GMT -5
It didn't spark or anything tho so that's why I think it's the solenoid
Post by floyd2133 on Oct 10, 2016 13:00:09 GMT -5
I just bought a new solenoid I'm headed home to hook it up
Post by gsx600racer on Oct 10, 2016 14:12:16 GMT -5
The solenoid has nothing to do with spark.
Post by floyd2133 on Oct 10, 2016 14:13:48 GMT -5
Well why did the solenoid use to spark when I bridge the wires. I said the solenoid isn't sparking. I didn't say I wasn't getting any spark
Post by floyd2133 on Oct 10, 2016 14:59:04 GMT -5
So I have replaced solenoid battery starter bendix and bendix bushing still can't get scooter to run bummer
Post by Cincikid on Oct 10, 2016 14:59:08 GMT -5
Are you getting 12v @ solenoid? I second what GSX is telling you. You need to find out if your battery is capable of starting the bike. Advanced, Autozone, batteries + or maybe a hobby store. Some one will test it. Let your fingers do the walking. (businesses will normally help out a potential customer) If the battery is good I would test each connection working back from you solenoid.
Post by floyd2133 on Oct 10, 2016 15:02:27 GMT -5
I have 3 battery's and I'm getting 13 volts at solenoid
