Post by floyd2133 on Oct 10, 2016 20:09:13 GMT -5
Starter is worn Ima ride it till my replacement come in and buy a new bendix
Post by floyd2133 on Oct 11, 2016 15:43:00 GMT -5
Look what i got ![](http://uploads.tapatalk-cdn.com/20161011/cd3f4f08f699abf121becfdd0f85f5c3.jpg) ![](http://uploads.tapatalk-cdn.com/20161011/a5e32e1fa66ef4e6a8a08bbe6f730e8a.jpg)
Post by floyd2133 on Oct 11, 2016 17:45:43 GMT -5
Look what i got ![](http://uploads.tapatalk-cdn.com/20161011/cd3f4f08f699abf121becfdd0f85f5c3.jpg) ![](http://uploads.tapatalk-cdn.com/20161011/a5e32e1fa66ef4e6a8a08bbe6f730e8a.jpg) Even though I charge it with this it has a hard time starting? I sprayed with carb cleaner then it crank for 5 sec gave sum gas n started. Let it run for 10 min turned off then tried to start 5 min later it would not start. I try to make sure bendix is not engaged on flywheel on start however does that matter? Additionally I ordered a new starter and bendix due to old starter will wear bendix gears so when Nea starter come new bendix will be replaced. So all in all I charge it starts turn off no start lastly it only seems to help start with carb cleaner
Post by niz76 on Oct 11, 2016 17:57:03 GMT -5
That's good that you got the correct charger to charge your lithium ion battery. Those Lio batts are much more sensitive to charging methods/over charging than the ol' lead acids so good job. A decent battery and good carb tune should have your scoot start up at the touch of the button and you should be able to start it up and shut it down and start it up about ten times over, even with a BBK...
Post by floyd2133 on Oct 12, 2016 14:51:18 GMT -5
Even though I charge it with this it has a hard time starting? I sprayed with carb cleaner witch made it easier. it crank for 5 sec gave sum gas n turned over. Let it run for 10 min turned off then tried to start 5 min later it would not start. So all in all I charge it starts turn off no start lastly it only seems to help start with carb cleaner
Any more suggestions
Post by niz76 on Oct 12, 2016 18:19:17 GMT -5
Have you done any carb tuning so that it starts easier? Tons and tons of information available here about it...
Post by floyd2133 on Oct 14, 2016 0:43:42 GMT -5
Ok so I started bike with new 12 volt lead acid batt it needed a boost from trickle charge however . I left it running with a sea foam treatment for a hour. Turned it off for a second . Tried to crank again nothing but what you see in video below. I even switched to a new 10gauge ground cable vimeo.com/187293534
Post by floyd2133 on Oct 14, 2016 1:07:58 GMT -5
However it cranks better with hand in back of carb in this video n suddenly stops when I take my hand off vimeo.com/187295312
Post by floyd2133 on Oct 14, 2016 6:25:25 GMT -5
Have you done any carb tuning so that it starts easier? Tons and tons of information available here about it... I haven't did carb tuning what are my options? Links??
Post by Cincikid on Oct 14, 2016 8:43:49 GMT -5
Scoot FAQ: left side of this page.
Post by floyd2133 on Oct 14, 2016 18:10:09 GMT -5
As I said before ordered new starter n bendix installed today no problems
Sent from my iPhone using Tapatalk
