Post by badpumpkin on Oct 8, 2016 13:11:22 GMT -5
Are there corresponding jet sizes to drillbits
Post by 90GTVert on Oct 8, 2016 16:37:05 GMT -5
Post by FrankenMech on Oct 8, 2016 20:58:55 GMT -5
It is best to purchase jets. Drilling jets is highly unreliable due to the profile of the drilled hole, chamfers, edges, burrs, surface finish, etc.
Post by 90GTVert on Oct 8, 2016 21:36:11 GMT -5
I like buying jets because it's simple. No drilling and then filling and re-drilling and so on. Pick what works. That said, it's not a bad idea to have a way to check your jets. I just found some of mine to be way off. A 105 was much smaller than a 110, to the point that one made it sputter and not run and the other made it soft seize.
Post by FrankenMech on Oct 9, 2016 17:27:32 GMT -5
The leading and trailing hole edge profile makes a huge difference in flow rates.
Post by badpumpkin on Oct 9, 2016 21:51:49 GMT -5
Brent, FrankenMech, thank you for your help, your information is awesome. This is the best forum. Brent another donation is coming your way.
