Post by floyd2133 on Oct 13, 2016 0:15:41 GMT -5
Bought a 12v deltran lith batt 2 weeks ago. Was charging it with a lead acid charger for a week and realized that I needed a Lithonia ion charger here's my multimeter test vid n pics of my charger? Is my battery bad what do you think? vimeo.com/187126551Battery someone told me this battery doesn't have enough cranking amps but it's a 12v why does it matter?
Post by floyd2133 on Oct 13, 2016 6:06:21 GMT -5
Well they issued me a refund this is the third bad battery I bought. I went from stock Chinese to 12v lead acid. To 12v lithium ion could someone suggest a good lithium batt since I heard lots was better than lead acid?
Post by humanshield on Oct 13, 2016 8:34:44 GMT -5
Consider this, your scooters charging system is not a "lithium ion" charger so if you can't charge the battery with a regular battery charger, how is it supposed to work in your scooter?
I have heard of other people having issues with those types of batteries in their scooters. But some may have good luck with them. I don't know.
Since you've had trouble with three of them, I would go back with a regular lead acid scooter battery.
And yes, I would say that battery is toast.
Post by floyd2133 on Oct 13, 2016 8:42:35 GMT -5
What brand batt do you recommend?
Post by humanshield on Oct 13, 2016 10:05:31 GMT -5
The brand is not too terribly important. They're all mostly cheap Chinese made batteries. Walmart has one that will work. Measure your battery compartment length, depth and width and get the largest battery that will fit and the cover will still close.
