Post by renagade281 on Oct 15, 2016 13:54:36 GMT -5
do i have to buy a whole new cylinder head now?
Post by jeff84 on Oct 15, 2016 14:41:30 GMT -5
no, you need to buy a tap and a stud (bolt with head cut off, threaded rod) that matches the tap.
Post by humanshield on Oct 15, 2016 16:51:18 GMT -5
do i have to buy a whole new cylinder head now? I know that feeling brother. Yep, drill and tap is the only cure. (other than new head.)
Post by aeroxbud on Oct 15, 2016 16:57:33 GMT -5
Could you not helicoil it?
Post by jeff84 on Oct 15, 2016 17:08:13 GMT -5
that is another option
Post by ThomasTPFL on Oct 16, 2016 10:13:23 GMT -5
What's it on? Stock 50? Yes, it's time for a new top end.
Expensive European BBK? Tap for a larger stud or for a helicoil.
If it were me in steel I'd probably drill and tap oversized, in aluminum I'd do a thread insert of some sort.
Post by gsx600racer on Oct 16, 2016 18:12:03 GMT -5
Like others have mentioned, either a get a expensive 6mm helicoil/thread repair kit or you could drill and tap for a 7mm and use this.
Post by 190mech on Oct 16, 2016 18:30:22 GMT -5
OR we could 'merican it with a 1/4"-20 tap and go from there...
Post by nelson on Oct 16, 2016 23:40:48 GMT -5
If you really wanna redneck it just get a 6/32 bolt run it all the way through and put a nut on the back side
Post by thxcuz on Oct 17, 2016 0:21:05 GMT -5
Get a new head. I've tried everything and my stud still fell out. Helicoil may work but it's expensive. I've tried to drill out and re tap.. no luck. Heads are cheap. Replacing it will save you a lot of headaches.. pun intended
Post by renagade281 on Oct 18, 2016 10:14:58 GMT -5
Get a new head. I've tried everything and my stud still fell out. Helicoil may work but it's expensive. I've tried to drill out and re tap.. no luck. Heads are cheap. Replacing it will save you a lot of headaches.. pun intended i see what u did there lol... yea im just gonna order a new head probably. its not for my scooter, its for the scooter im fixing for my mom.. its like 30 bucks shipped for a new head
Post by tortoise2 on Oct 18, 2016 10:51:45 GMT -5
Post by thxcuz on Oct 18, 2016 11:24:21 GMT -5
Woah? That's a thing? I should have tried that. I still have my bad head...I might visit my helpful hardware man and give it a try
Post by renagade281 on Oct 19, 2016 12:34:02 GMT -5
i thought about that too but now I done broke a bolt off in the thread
