Post by jkeney on Nov 9, 2016 11:03:54 GMT -5
Not a whole lot at play here. It's only one of three things. 1. Valve seals. 2. Piston rings. 3. Head gasket.
phatmanxxl
Post by phatmanxxl on Nov 9, 2016 13:59:28 GMT -5
Not a whole lot at play here. It's only one of three things. 1. Valve seals. 2. Piston rings. 3. Head gasket. Just bought a new valve head, new head gasket...gotta be the rings even though they look fine. If not then I give up. Anybody suggest some rings I should get? 47mm 80cc I found some on scooter parts express but I'm wary on spending $21 on something that may not be the problem. Should some $10 ones be just as good?
Post by 90GTVert on Nov 10, 2016 8:03:36 GMT -5
I'd just try to find something made in Taiwan instead of China if possible. A member here used to buy Hoca rings for cheap Chinese BBKs regularly, but I'm not seeing them on PFS' site ATM. I found NCY elsewhere, but they want $30 for the rings. Here are Naraku rings : scootertuning.ca/en/pistons-gaskets/860009-piston-ring-set-naraku-72cc-gy6-50cc.htmlYou may be fine with another set of Chinese rings. It's not like they're all bad, I mean our stock scoots are using all Chinese parts and many run a long time before any internal engine issues. Whatever you choose, inspect the bore and again make sure you check/set the end gaps on the new ones.
phatmanxxl
Post by phatmanxxl on Nov 10, 2016 12:47:00 GMT -5
I'd just try to find something made in Taiwan instead of China if possible. A member here used to buy Hoca rings for cheap Chinese BBKs regularly, but I'm not seeing them on PFS' site ATM. I found NCY elsewhere, but they want $30 for the rings. Here are Naraku rings : scootertuning.ca/en/pistons-gaskets/860009-piston-ring-set-naraku-72cc-gy6-50cc.htmlYou may be fine with another set of Chinese rings. It's not like they're all bad, I mean our stock scoots are using all Chinese parts and many run a long time before any internal engine issues. Whatever you choose, inspect the bore and again make sure you check/set the end gaps on the new ones. Thanks I'll buy those.
phatmanxxl
Post by phatmanxxl on Nov 21, 2016 9:58:49 GMT -5
I'd just try to find something made in Taiwan instead of China if possible. A member here used to buy Hoca rings for cheap Chinese BBKs regularly, but I'm not seeing them on PFS' site ATM. I found NCY elsewhere, but they want $30 for the rings. Here are Naraku rings : scootertuning.ca/en/pistons-gaskets/860009-piston-ring-set-naraku-72cc-gy6-50cc.htmlYou may be fine with another set of Chinese rings. It's not like they're all bad, I mean our stock scoots are using all Chinese parts and many run a long time before any internal engine issues. Whatever you choose, inspect the bore and again make sure you check/set the end gaps on the new ones. Got the Taiwanese rings in, scoot started up on the first kick. No smoke and oil billowing out. Thanks! Next problem, keeping my balls warm while riding in December! :-P
Post by Cincikid on Nov 21, 2016 10:56:05 GMT -5
Post by dexameth on Nov 21, 2016 18:31:05 GMT -5
I'd just try to find something made in Taiwan instead of China if possible. A member here used to buy Hoca rings for cheap Chinese BBKs regularly, but I'm not seeing them on PFS' site ATM. I found NCY elsewhere, but they want $30 for the rings. Here are Naraku rings : scootertuning.ca/en/pistons-gaskets/860009-piston-ring-set-naraku-72cc-gy6-50cc.htmlYou may be fine with another set of Chinese rings. It's not like they're all bad, I mean our stock scoots are using all Chinese parts and many run a long time before any internal engine issues. Whatever you choose, inspect the bore and again make sure you check/set the end gaps on the new ones. Got the Taiwanese rings in, scoot started up on the first kick. No smoke and oil billowing out. Thanks! Next problem, keeping my balls warm while riding in December! :-P I'm glad this is solved!! I'm having the same issue, and I have Taiwanese rings just sitting on my table. Just waiting for the time to install them (Wednesday can't come sooner!)
Post by greggkinney on Nov 26, 2016 16:06:46 GMT -5
lmgdao just be careful removing these if you use the sticky side!!!!
Post by greginisn on Jun 3, 2017 4:34:08 GMT -5
Those things could knock your sperm count to zero,
BEWARE!
