Post by renagade281 on Nov 8, 2016 9:06:41 GMT -5
Post by humanshield on Nov 8, 2016 9:52:13 GMT -5
What kind of vinyl cutter do you have?
Post by hamsun on Nov 8, 2016 10:28:21 GMT -5
Good work!
Post by Deleted on Nov 8, 2016 10:52:54 GMT -5
I think that looks really good man! Nice job.
Bill
Post by humanshield on Nov 8, 2016 11:31:47 GMT -5
Ummm....excuse me....but I think you have MY CVT cover
Post by renagade281 on Nov 9, 2016 5:03:28 GMT -5
I have a 36" vinyl cutter. I forgot what brand. It came from sign warehouse
Post by eclark5483 on Nov 9, 2016 5:06:10 GMT -5
I would think that would melt when the cover heats up. Maybe not... guess you'll find out.
Post by aeroxbud on Nov 9, 2016 5:11:22 GMT -5
I think it came out really good
Post by renagade281 on Nov 9, 2016 5:15:13 GMT -5
I would think that would melt when the cover heats up. Maybe not... guess you'll find out. the black and the silver paints are both high heat engine paint. Up to 500 degrees.
Post by eclark5483 on Nov 9, 2016 6:10:08 GMT -5
Oh duh, you cut the vinyl then painted it using the template.. OK, don't mind me, I'm an idiot. I was thinking you cut the lettering from the vinyl and stuck it on there.
Post by jkeney on Nov 9, 2016 10:13:02 GMT -5
The CVT cover and clutch Bell do not get hot enough to damage regular spray paint. Regular spray paint does not stand up as well to gasoline dripping on it though.
Post by jkeney on Nov 9, 2016 10:13:44 GMT -5
Hell even the valve cover can be painted with normal rattle can.
Post by greggkinney on Nov 16, 2016 0:45:57 GMT -5
The CVT cover and clutch Bell do not get hot enough to damage regular spray paint. Regular spray paint does not stand up as well to gasoline dripping on it though. true. I prefer old school lacquer paints and clears, to me they spray easily.BUT gas will goo it up for sure. (Dont ask
Post by Deleted on Nov 19, 2016 18:05:59 GMT -5
My belt cover is painted with plain old Krylon, heat has never been an issue with it, it's held up quite well actually.
