Post by renagade281 on Jan 3, 2017 9:34:57 GMT -5
Got a buddy that says his scooter needs a "tune up" and a carb clean. Are these a lot different than working on the Chinese Scooters I'm used to?
Post by lordhater on Jan 3, 2017 9:42:47 GMT -5
Quite a bit different but not horrible,,,once you get the hang of it ,,
Post by renagade281 on Jan 3, 2017 13:52:46 GMT -5
I guess all engines have the same concept. Some just designed different
Post by ThomasTPFL on Jan 3, 2017 22:25:38 GMT -5
Carb shouldn't be too weird. The rest is. Oddball double clutch two speed transmission. You pedal it backwards to start it. Strange to me.
Got to Moped Army if you need real help in it.
Post by gsx600racer on Jan 4, 2017 2:49:06 GMT -5
Parts should be fairly easy to get if needed, Tomas has been around for awhile. Treatland should be a good source for parts.
