Post by oldgeek on Jan 29, 2017 23:31:25 GMT -5
Post by gsx600racer on Jan 30, 2017 5:50:19 GMT -5
Cool idea. My only concern is the control of the tool. I bet she jumped around using a flute-ed cutter. You might want try a sanding drum instead. It wont "bite" in as much. It might take longer to do but will be more controlled.
I tried sketching something along the same lines as your idea and the more I sketched, the more complicated it got. The premise was to have the tool controlled in a guide and you could manually adjust it to control the diameter. It would cost more to make then buying the NYC case cutting tool. If you think you might do more than a few cases, id consider buying it. You could also offer service for a small fee and you could pay for the tool in no time.
Post by 190mech on Jan 30, 2017 6:35:39 GMT -5
I like the idea!Always wanted to build up something and have it as a rental tool for the members here,not enough hours in the day though!!
Post by oldgeek on Jan 30, 2017 7:17:42 GMT -5
Cool idea. My only concern is the control of the tool. I bet she jumped around using a flute-ed cutter. You might want try a sanding drum instead. It wont "bite" in as much. It might take longer to do but will be more controlled. I tried sketching something along the same lines as your idea and the more I sketched, the more complicated it got. The premise was to have the tool controlled in a guide and you could manually adjust it to control the diameter. It would cost more to make then buying the NYC case cutting tool. If you think you might do more than a few cases, id consider buying it. You could also offer service for a small fee and you could pay for the tool in no time. Believe it or not the the whole rig was very stable. The mass of the cutter, speed of the cutter is important. The feed rate is easy to control. The first cut using the template looked very smooth until I started freehanding the rest of the cut. I may incorporate some kind of bearing for the cutter shaft where it rides on the template, but it does not really need it.
Post by 2TDave on Jan 30, 2017 7:46:51 GMT -5
Having cut cases freehand I like the idea. The cylinder area isn't as big of a pita to me as the crank wheel area on the deep side case half. I seem to remember you having a rig for that as well.
Post by gsx600racer on Jan 30, 2017 8:22:27 GMT -5
Cool idea. My only concern is the control of the tool. I bet she jumped around using a flute-ed cutter. You might want try a sanding drum instead. It wont "bite" in as much. It might take longer to do but will be more controlled. I tried sketching something along the same lines as your idea and the more I sketched, the more complicated it got. The premise was to have the tool controlled in a guide and you could manually adjust it to control the diameter. It would cost more to make then buying the NYC case cutting tool. If you think you might do more than a few cases, id consider buying it. You could also offer service for a small fee and you could pay for the tool in no time. Believe it or not the the whole rig was very stable. The mass of the cutter, speed of the cutter is important. The feed rate is easy to control. The first cut using the template looked very smooth until I started freehanding the rest of the cut. I may incorporate some kind of bearing for the cutter shaft where it rides on the template, but it does not really need it. This is sotra what I tried to envision.
The tool holder was pin-ed into to face plate so it could not twist and followed the slot. The tool holder was adjustable on a slide so you could control the depth of cut. Yeah I got too much time on my hands.
Post by oldgeek on Jan 30, 2017 12:21:21 GMT -5
Having cut cases freehand I like the idea. The cylinder area isn't as big of a pita to me as the crank wheel area on the deep side case half. I seem to remember you having a rig for that as well. Yes, the other tool works much better now since I upgraded to a more powerful flex tool, a bigger and better cutter and a few other modifications .😀
