Post by floyd2133 on Feb 1, 2017 13:52:13 GMT -5
So I put n a Bbk 3 months ago I have been waiting on a back tire to test it cause mine was busted finally got tire. It cranks and idles however it won't move when I sit on it . N tire only moves at 3 rpm vimeo.com/202080957
Post by jaga4life on Feb 1, 2017 13:59:15 GMT -5
Sounds like a bad crank to me.
Post by gsx600racer on Feb 1, 2017 14:03:07 GMT -5
From the vid, almost sounds like the valves are out of adjustment.
Post by floyd2133 on Feb 1, 2017 14:03:21 GMT -5
Sounds like a bad crank to me. A bad crank?
Post by floyd2133 on Feb 1, 2017 14:06:56 GMT -5
From the vid, almost sounds like the valves are out of adjustment. I will check the valves then get back to you
Post by floyd2133 on Feb 1, 2017 16:30:33 GMT -5
From the vid, almost sounds like the valves are out of adjustment. You were right vimeo.com/202104911
Post by floyd2133 on Feb 1, 2017 17:00:29 GMT -5
From the vid, almost sounds like the valves are out of adjustment. So I changed valves now they are making a popping sound vimeo.com/202110184
Post by gsx600racer on Feb 1, 2017 17:05:00 GMT -5
Sorry, I cant open the last 2 vids.
Post by floyd2133 on Feb 1, 2017 17:06:00 GMT -5
Post by floyd2133 on Feb 1, 2017 17:09:35 GMT -5
Sorry, I cant open the last 2 vids. The intake valve is popping with no crank
Post by floyd2133 on Feb 1, 2017 17:24:29 GMT -5
It's working now for sum reason it's at dead center when the cyx symbol is in the middle ; not the hole
Post by stoneforth on Feb 1, 2017 18:06:49 GMT -5
I once got a crank where the chain sprocket was in the wrong place so I couldn't line up timing marks on the flywheel and cam. Might be something to check.
Post by gsx600racer on Feb 2, 2017 6:26:21 GMT -5
Based on your first vid(seeing the other 3 go to missing links) I see and hear several things wrong. The engine is noisy, so I would guess the valves are out of adjustment and possibly the timing chain tensioner is out of adjustment. The lack of power could be from the valve timing is off. The popping can be from the valves adjusted too tight(valve still open) or the timing is off. You are missing the breather tube off the valve cover. Whats up with you rear tire ? It wobbles when it is spinning. It also looks like its not seated on the rim properly. @2:30(in first video) on left side of tire and wheel, I can see outside of the rim. This should be impossible seeing the tire should be wider than the rim.
Post by FrankenMech on Feb 3, 2017 1:00:48 GMT -5
Where is the air cleaner in the first video?
No air cleaner == no run.
Post by jeff84 on Feb 3, 2017 14:17:28 GMT -5
yeah I was going to say the same thing. with a wide open intake like that you are going to need a really big main jet, and you will never get good air velocity that way. you need at least some sort of intake runner.
I have run open intake like you have before and the only way it would run well, was by using tape to cover most of the intake opening, to lean out the mixture and allow the air speed to not drop through the floor while the intake valve is closed. remember its a single cylinder, so there aren't other cylinders continuing to draw air through the intake during the firing and exhaust strokes. that's why big cams don't give you that loppy idle you hear in multi cylinder engines.
a short 3 to 6 inch piece of radiator hose makes a good intake runner, and you can mount a cone style air filter on the end of it. if you don't still have the stock intake snorkel and air filter box. if you go this route, you have to use hose clamps. even if it seems like a really snug fit, it will fall off while you are riding if its not clamped securely to the carb.
