Post by Senna1Rossi on Feb 6, 2017 14:02:22 GMT -5
Would a 2.75/10 tyre work for the front or only an 80/90-10. Just wondering as i cant find anything in both 80/90 & 90/90 here in Canada its either or & i dont want 2 different tyres on my scoot because i want the larger rear tyre for better clearance for my exhaust. But a 2.75-10 is similar to a 80/90 any idea if it would fit?
What scoot is it going on? I think 2.75 is narrower than 80/90-10. 3.5 is similar to 90/90-10... So you may look into 3.0-10 tires. Did you look in Amazon??
Post by tiny on Feb 6, 2017 17:05:25 GMT -5
Post by Senna1Rossi on Feb 6, 2017 18:12:01 GMT -5
I don't think they have their size chart correct... Under the "Metric" column, the # after the "/" is the aspect ratio, but on the "Std Inch" the # after the "/" is more like "-". Meaning it's approx. "5.00 - 5.10", so those number doesn't really correlate.
5.1" is 129.54mm
3" = 76.2mm, so it's named most likely 80 (wide) / # (aspect ratio) - # (rim diameter)
