My new Icebear 150. And it doesn't seem to want to run.
Feb 20, 2017 22:40:47 GMT -5
90GTVert likes this
Post by bluegoatwoods on Feb 20, 2017 22:40:47 GMT -5
That's not all bad. I'll figure out what's wrong. It'll be good experience for me.
I'll start with a photo of it before I started the PDI.
Then I found a couple of small surprises. This is the type of scooter where the gas tank is under the deck. And the battery gets mounted almost where the gas tank ought to be.
I got her all buttoned back up this morning. I put a pint of gasoline into it from the gas can that I use for my lawnmower. I'm beginning to have some doubts about that since this fuel is from last fall. But I did treat it with Sta-Bil and I used the same fuel to start up my red Taotao with no trouble.
I cranked her for a good long time with no results. So I opened the fuel line right at the fuel filter and squeezed some gasoline into the line that leads right into the carburetor. And then she started up nicely.
By the way, I'm guessing that there's no fuel pump of any kind on these scoots with the low gas tank. I certainly couldn't find one. Is the fuel drawn to the carb by intake vacuum?
So then I went up to the gas station and filled my can with fresh gasoline and put a gallon into this bike. She started up really well several times. Idled nice and revved nice.
So I spent a little time tightening down a few more loose ends and tried to take her out for a test ride in the neighborhood. The bike was idling nicely while I was turning it around. I goosed her a couple of times while turning around. These were the first times she'd pushed herself under her own power. Gently, it's true. But she did it without seeming to have any trouble.
When I gave the throttle a real twist, to start off down the driveway, she sputtered and stalled. For a while I could coax a bit of idling out of her. But any throttle at all would kill it immediately. And the idling wasn't too good either. It would last four or five seconds, and sometimes a good deal long. But sooner or later she'd sputter and die.
I was able to verify fuel to the carburetor. So that made me suspect the carb. So I swapped that out for another brand new carburetor. But the symptoms with the new carb are identical. And trying to get it started up this time was enough to run the battery down. So I shelved this project for today and put the batter on the battery tender.
The fact that the new carb behaved exactly as the stock card did makes me think, of course, that fuel is not my trouble.
I'm going to have to pull the body panels back off and have a look at that spark plug. It's the stock plug and boot, by the way. I figured I could get away using those for just a little while anyway. That might have been a bad bet. I did manage to undo the wire from the boot, trim it back 1/4 inch and re-install. But that didn't make any difference.
When I can work on it again this weekend I guess I'll pull the spark plug wire and boot from the red Taotao and try that in the icebear. Maybe the coil, too. If they're interchangeable. Not all parts will swap between these two bikes. I can see that already.
In the meantime suggestions, and even mere guesses, are welcome. Thanks.
Here's a pic of my 'stable'. Just for fun.
