Post by mrhooper on Feb 23, 2017 23:43:33 GMT -5
Sorry guys a know its kinda off topic but
Hello everyone, I got a pit bike for free they said it did not run because of electrical. But the real problem was the nut and adjuster for the intake valve was gone. I replaced it but found a nut on the lower valve cover but no adjuster. There is a oil gallery on the bottom but besides that I dont have any idea were it could go becaue the oil gallery is the only exit. If anyone has any ideas I would greatly appreciate the input. Ps. it is a lifain 125
Post by gsx600racer on Feb 23, 2017 23:55:49 GMT -5
I would take the top and bottom valve covers, the front rocker cover, and the side timing gear cover and take a peek in. You might get lucky, if not you might have to open the engine up. Could also remove the engine and drain the oil and move the engine around and you might get the adjuster screw to fall out of on of the removed covers.
Post by mrhooper on Feb 24, 2017 0:51:45 GMT -5
Ok will try
Post by 90GTVert on Feb 25, 2017 8:25:23 GMT -5
Stick a magnetic retrieval tool in anywhere you can fit it (like through the valve adjuster caps and drain plug hole) and see if that finds anything.
Post by mrhooper on Feb 25, 2017 10:55:08 GMT -5
Ok thank you
