Post by dachurchpcguy on Feb 25, 2017 14:19:16 GMT -5
I decided to ride all year for the first time since 1980. I'm going to document the mods I've made to my scooters to allow for reliable running in sub 20° F (-7°C) weather. This will not be about riding gear, just mods to the scooter. These little engine do NOT like anything colder than freezing. I will also note failed mods to save people some time.
2016 TaoTao ATM50
Mod 1
The first thing I tried was to cover the intake with three layers of T-shirt cloth to enrich the mixture, too rich, as was two layers. One layer of material allowed the engine to start just fine once the fuel got to the carb. It takes a bit for the vacuum petcock to release fuel in the cold, I normally put my hand over the intake to increase vacuum for a couple seconds.
So, it starts and runs okay with the one piece to cloth secured via a girls hair scrunchie. (Google it, if you don't have girls.) I let the bike warm up as I put my helmet and gloves on. The big problem is that it will not go faster than about 20mph. I rode with it on for a couple blocks and removed it to get up to speed. So that works, but it's a bit tedious to do every time you ride.
Mod 2
The second mod is so simple, I kicked myself for not trying it... unplug the enrichment wire! I have to manually choke the intake by covering about 2/3rds of it with a finger to get it to start. Once started it runs okay for 1/2 mile of so, then just fine after that. This mod has been documented somewhere before, simple but effective. I plan to add an enrichment switch to the bike later so I can turn the circuit on and off at will.
Mod 3
I keep my scooter's battery plugged into a battery tender when I don't ride. These little batteries die quickly in the cold. It's currently an issue because I keep the battery side bolted on and it just sort of flops about. I'll be installing one of my RV connectors noted in the Veken mods section.
These mods work well enough for now since this scoot will become my backup ride when I finish my hybrid build.
2016 TaoTao ATM50
Mod 1
Mod 2
Mod 3
