Post by joggybro on Apr 6, 2017 6:19:25 GMT -5
OK guys so I've just ordered a jog 90 engine case, Been looking around for crankshafts to fit, I can get the original jog90 crank buy I'm looking for a high performance crankshaft for it.
Has anyone any links?
Post by AtariGuy on Apr 6, 2017 23:32:36 GMT -5
OK guys so I've just ordered a jog 90 engine case, Been looking around for crankshafts to fit, I can get the original jog90 crank buy I'm looking for a high performance crankshaft for it. Has anyone any links? check on scootertuning.ca and reference the vento triton. Those bits ought to get you into a 90 style crankshaft (aka 12mm pin with large variator splines and large flywheel shaft)
Post by niz76 on Apr 7, 2017 0:52:13 GMT -5
Post by joggybro on Apr 7, 2017 1:26:24 GMT -5
Post by niz76 on Apr 7, 2017 1:40:51 GMT -5
Keep in mind that it's a 'stroker crank'. Has a longer stroke than stock...
Post by joggybro on Apr 7, 2017 4:09:02 GMT -5
Thanks bro could you link me to some high end crankshafts so I can have a look thanks
Post by 90GTVert on Apr 7, 2017 6:38:39 GMT -5
www.g-forcepowersports.com/CRANKSHAFTSMiniQuad-s/3226.htmYou'll need to know what kind of build you want before you choose a crank. The high end cranks are meant for high end cylinders. Varying strokes, conrod lengths, and gudgeon pin sizes don't let them mix and match with just anything. Budget is a big factor here. Huge price difference in the high end ~90cc stuff and the Taiwan crank and 54mm iron bores.
Post by joggybro on Apr 7, 2017 7:54:46 GMT -5
www.g-forcepowersports.com/CRANKSHAFTSMiniQuad-s/3226.htmYou'll need to know what kind of build you want before you choose a crank. The high end cranks are meant for high end cylinders. Varying strokes, conrod lengths, and gudgeon pin sizes don't let them mix and match with just anything. Budget is a big factor here. Huge price difference in the high end ~90cc stuff and the Taiwan crank and 54mm iron bores. Going for the 54mm cylinder with a view to at a later date maybe fit the polini big evo 96cc, I'm guessing the 45mm stroke will fit both cylinders?? ATM I'm just really wanting a full circle high performance crankshaft for 96cc(54mm cylinder)
Post by 90GTVert on Apr 7, 2017 9:13:04 GMT -5
Plan 2 separate setups. I think the Big Evo uses a 13mm pin, 12mm for the Taiwan stuff so you can forget the same crank working with both. If you're gonna spend a small fortune on a Big Evo setup, you don't want a bunch of compromises anyway. Remember a setup like that will need the crank, cylinder, and pipe all matched... plus you should have a race ignition, full CVT setup to keep it revved, bigger carb.... No sense in planning to be on a tight budget.
Post by paceneedsstides on Apr 7, 2017 13:06:46 GMT -5
I think one of the BIG EVO kits comes with all the stuff you need to convert it but thats BIG MONEY right there
Post by fugaziiv on Apr 7, 2017 13:30:05 GMT -5
Post by fugaziiv on Apr 7, 2017 13:32:53 GMT -5
Plan 2 separate setups. I think the Big Evo uses a 13mm pin, 12mm for the Taiwan stuff so you can forget the same crank working with both. If you're gonna spend a small fortune on a Big Evo setup, you don't want a bunch of compromises anyway. Remember a setup like that will need the crank, cylinder, and pipe all matched... plus you should have a race ignition, full CVT setup to keep it revved, bigger carb.... No sense in planning to be on a tight budget. Also really good advice. If you're going to step up to Big Evo and spend that kind of cash, just build that motor out on it's own and do it right. Compared to Big Evo, maintaining a separate engine built with Taiwanese parts is chump change. Matt
Post by pigkut on Nov 16, 2017 4:18:52 GMT -5
