Post by mets6986 on May 7, 2017 12:32:34 GMT -5
So I bought a 49cc tao tao 2015 with 50 miles on it. Now it has about 700 and last week started running really sluggish. When I first start it up it tops out at 15 mph and will stall when I stop. After riding it for a few minutes it will gradually get up to 30 mph but the acceleration is a lot slower then what it was. I changed the oil two weeks go and it ran fine for a few days and then this started happening. Any input would be great because I'm clueless.
Post by tortoise2 on May 7, 2017 12:42:57 GMT -5
Any input would be great because I'm clueless. Considering the abundance of troubleshooting internet information on the 139QMB engine . . not seeing much initiative or mechanical aptitude on your part. Can't fix lazy!
Post by mets6986 on May 7, 2017 13:07:17 GMT -5
Really? This is the first place I tried to look. I didn't know there was a lot of information out there but thanks for the reply douchebag.
Post by gsx600racer on May 7, 2017 14:17:32 GMT -5
Really? This is the first place I tried to look. I didn't know there was a lot of information out there but thanks for the reply douchebag. Pay no attention to the other member, he/they do not reflect the other members here that are more positive and will try to give you a hand. I would start with the basics, check the fuel system, fuel tank(water in fuel) filter, hoses. Wouldn't hurt to pull the carb and remove the fuel bowl and give everything a good cleaning. You can check this link where there is a wealth of information. 49ccscoot.proboards.com/board/9/49ccscoot-com-tech-library
Post by mets6986 on May 7, 2017 21:36:30 GMT -5
Thanks a bunch gsx very helpful. I will have a full day ahead of me trying to see what's wrong but good tip to start with the basics.
Post by FrankenMech on May 13, 2017 21:18:43 GMT -5
Too much oil in the case can cause sluggish performance.
Check the compression and make sure the valves are adjusted right.
Post by Cincikid on May 14, 2017 8:14:57 GMT -5
^^ Now that it has a couple miles on it, it may be time to adjust the valve lash.
Post by niz76 on May 14, 2017 9:37:35 GMT -5
^^ Now that it has a couple miles on it, it may be time to adjust the valve lash. +1
Post by niz76 on May 14, 2017 9:38:41 GMT -5
