Post by humanshield on May 10, 2017 19:00:52 GMT -5
I keep shattering variators.....well,...the guide posts for the ramp plate anyway (there are 3 of these posts) Anyone else have this problem with a 1 fiddy and what did you do? PS...I doubt it's "too much power"....more like cheap Chinese junk parts
Post by 90GTVert on May 12, 2017 8:33:56 GMT -5
I definitely didn't have that issue. DrPulley is a quality variator from what I've seen, though my stock variator seemed just fine too. Make sure the bushings/slides aren't getting worn out. If there's much play there, it could cause more problems from the slack causing more of an impact from sort of slapping.
Post by 2stroked on May 12, 2017 21:24:03 GMT -5
humanshield, No offense intended at all, and I am sure this is not true but is it possible the rollers/sliders you are using are either too wide or too narrow? I know you're more experienced in the scoot world than I am, but figured it may be a very slim chance?
