Hard start
May 18, 2017 15:28:55 GMT -5
via mobile
Post by marine25 on May 18, 2017 15:28:55 GMT -5
Here's my problem scooter won't start by it self but if I put fingers over carb it will start an run what I have done changed carb changed fuel lines an vac lines changed vac pump new battery turns over great but doesn't catch till I put fingers over carb back of carb then fires right up any suggestion on this
Post by Cincikid on May 18, 2017 16:08:26 GMT -5
What are you working on? 49cc 4 stroke? How many miles? What size and brand carb? What size is the main jet? Was it running before the changes? How long ago? How does it run once started? ?? Covering a portion of the back of the carb richens the air-fuel mixture. Your not getting enough fuel. If you suck on the vac line for the petcock does the fuel flow freely? Oh, and Welcome! Thank you for your service.
Post by pinkscoot on May 18, 2017 18:29:30 GMT -5
Do you have the stock air box in place?
Post by acvw74 on May 18, 2017 19:25:11 GMT -5
Check your compression
