Post by dexameth on May 19, 2017 16:32:41 GMT -5
So there's 2 versions of the QMB139 motor. Short and long case. Why is the belt skinnier on the long case? 17.5mm on the 729 belt, 18mm on the 669. I don't understand the reason...
If I have one each of these motors, and buy the exact same aftermarket clutch and variator, the short case will use a wider belt and the long case will be skinnier.
I guess I may just be too bored at work...
Post by acvw74 on May 19, 2017 19:39:17 GMT -5
There is one other qmb139...extra long case. It has a 788 18 1 belt.
Post by jeff84 on May 19, 2017 19:51:12 GMT -5
math. that's all I can say. I'm bad at math
Post by jeff84 on May 20, 2017 2:25:51 GMT -5
if you can answer this question in detail, you should get a job as a cnc machinist or better.
Post by stepthrutuner on May 20, 2017 3:37:36 GMT -5
Specs are often wrong. Especially with China scoots.
