scooternoob
Scoot Junior
Post by scooternoob on May 21, 2017 12:55:38 GMT -5
Hey all. So I'm installing my new Malossi Multivar as well as a Malossi Fly clutch on my 1998 Yamaha Jog Next Zone CY50 2T
What are the appropriate size sockets that i will need? I've read 17mm for the Variator nut and possibly a 38mm or 41mm for the clutch spring nut..?
any help would be greatly appreciated!
Also, How important is it to weigh each roller weights as well as grease the bearing/spacer on the clutch?
Post by geoffh on May 23, 2017 16:16:11 GMT -5
Have look round in the two stroke tech section from the home page,it,s covered in there,most folk seem to use an electric impact wrench on the variator and an adjustable spanner and a pair of nike trainers on the clutch .I,m old school and use a special tool to hold the variator and a torque wrench to finish off.The socket sizes sound about right,no need to weigh the rollers but keep each set together so you don,t unbalance them.Best not to get any grease near the clutch mine runs just fine dry.IMO change each part, try it, note down the changes then move on to your next mod,it,s easy to throw it all in but difficult to back track if you have trouble,have a look on you tube,I,ll post pics if you need more help. geoff
Post by pinkscoot on May 23, 2017 17:26:44 GMT -5
Post by prestonshort06 on Feb 5, 2018 5:02:44 GMT -5
Hey all. So I'm installing my new Malossi Multivar as well as a Malossi Fly clutch on my 1998 Yamaha Jog Next Zone CY50 2T What are the appropriate size sockets that i will need? I've read 17mm for the Variator nut and possibly a 38mm or 41mm for the clutch spring nut..? any help would be greatly appreciated! Also, How important is it to weigh each roller weights as well as grease the bearing/spacer on the clutch? know why by any chance my 49cc taotao a1 is hard to push or roll? i have to put alot of muscle into it to move it place to place
Post by geoffh on Feb 5, 2018 15:38:36 GMT -5
Preston?first guess is a brake stuck on or the clutch is locked up,read up in the technical section using pinkscoots links above.
geoff
