Post by 180°off on May 24, 2017 0:47:16 GMT -5
Post by 180°off on May 26, 2017 20:05:12 GMT -5
Thanks for all the help!
Post by gsx600racer on May 27, 2017 22:35:47 GMT -5
You're welcome.
Post by 90GTVert on May 31, 2017 10:50:08 GMT -5
What most would do to get the carb size is measure the ID of the outlet. I think the proper way is to measure the venturi. If it's an oval, then you'd need to find the area and the size would be the area of a circle that matches the area your oval has.
All the pics are CV (constant velocity) carbs.
Post by knobby on May 31, 2017 12:17:35 GMT -5
3rd jet is likely for the choke circuit.
Post by 180°off on May 31, 2017 17:37:26 GMT -5
Are the carbs with the diaphragm that look like a T almost, better than the carbs with a round diaphragm? And is the mikuni carb better than the khein carb?
Post by knobby on May 31, 2017 18:10:39 GMT -5
You talking about slide shape? Round slides can run really good too..
What is it going on? I'd run which ever carb is off of an engine closest to the engine you've got.
