waqr
Post by waqr on May 24, 2017 5:58:11 GMT -5
Hi!
How do you now that the oil pump is bad in a GY6 50cc motor? I have a ticking sound that I can hear from the crankcase and since there is no play in the bearings I suspect the oilpump. Valve are also adjusted properly.
Also, in the manual it says that there are som seals that you should replace with the oilpump. Which seals are this?
Many thanks!
waqr
Post by waqr on May 27, 2017 3:32:33 GMT -5
So this is how my engine sounds. Is it some weird sounds going on or am I only getting very picky about how the engine sounds?
Post by gsx600racer on May 27, 2017 11:05:53 GMT -5
Have you checked/adjusted the valves?
waqr
Post by waqr on May 27, 2017 11:11:16 GMT -5
Yes, intake 0.003 and exhaust 0.004.
Post by FrankenMech on May 27, 2017 18:15:20 GMT -5
I don't hear a thing wrong, but then my ears are shot.
