Post by V90Performance on May 27, 2017 21:16:11 GMT -5
I brought a real 20mm carburetor off of scooters to go. It fixed my starting problem with the starter. My 18mm carb had a 95 main jet. I swapped it to the 20mm but it is running lean since acceleration and top speed has been affected. Should i jump to the 100 main jet? What other tuning advice can you give me about the 20mm carb? Running 50mm BBK with cold air intake and shorty exhaust.
Post by gsx600racer on May 27, 2017 22:27:35 GMT -5
Give the 100 main jet a shot or go bigger.
Post by V90Performance on May 27, 2017 22:48:01 GMT -5
Sounds like a plan, il give it a shot.
Post by dan50 on May 28, 2017 1:59:34 GMT -5
I put a #90 main jet in my 20mm carb for my 47mm BBK build (free-flow air filter and exhaust). It also was running lean. More air means you need more gas, even on a stock engine. A #100 main jet seems about right.
Post by V90Performance on May 28, 2017 8:37:06 GMT -5
Yeah that logic makes sense. Thanks.
Post by dan50 on May 29, 2017 0:02:36 GMT -5
I'm not a mechanic, so with carb jetting, it's a lot of trial & error to get it tuned. I thought a #90 would be plenty big, obviously not (stock carb on 50cc engine had #78 and was correct mix).
