ben
Scoot Newb
Post by ben on May 29, 2017 15:00:40 GMT -5
Gettin ready to install muy first bbk On a139qmb. Wondering what the two brown cylinders with an o ring on one side and a spring on the other are for? Can't find any references in install guides, including 90gt vert's here... Any clue? I'll try to figure out how to add a picture here...
Post by tortoise2 on May 29, 2017 15:32:34 GMT -5
Valve stem oil seals?
ben
Scoot Newb
Post by ben on May 29, 2017 17:11:19 GMT -5
Thanks! But that's not it, it's much smaller. The spring is wrapped around the end just like a metal o ring, and that end is beveled and small enough to fit inside the wrist pin interior... I'm sure it doesn't belong there, but for reference on size. Whole piece is maybe .5 in diameter and .5 in long.
ben
Scoot Newb
Post by ben on May 29, 2017 17:13:48 GMT -5
ben
Scoot Newb
Post by ben on May 29, 2017 17:15:32 GMT -5
And I guess while I'm asking questions, what's the brass ring pictured in the middle of the gaskets for as well?
Post by greggkinney on May 29, 2017 22:55:40 GMT -5
those are the valve seals and an exhaust gasket
Post by greggkinney on May 29, 2017 23:02:26 GMT -5
the discription list them as valve oil seal and on down it says exhaust gasket. if your valve srals are good i wouldnt bother changing them. theyare included to make it more of an overhaul kit.
Post by dan50 on May 30, 2017 1:38:17 GMT -5
Ditto on what greggkinney said. When I started installing my 47mm BBK, I had to find out what the valve seals were. Click on 'Manuals' on the left of the screen, and download the 139QMB engine manual. It has exploded diagrams of where everything goes as well as torque specs. Very handy Reference Manual. You need Adobe Reader to read it offline, but Adobe Reader is free from www.adobe.com .
Post by jeff84 on May 30, 2017 1:43:45 GMT -5
little rubber boots. that's my official answer
Post by 90GTVert on May 30, 2017 8:30:25 GMT -5
They're shown here being removed and installed.
