Post by thegreatalways on May 29, 2017 18:28:20 GMT -5
Hey fellas my kill switch is not working and my starter button is not working only way for me to shut it off is by putting hand over exhaust it's a tao tao summer
Post by V90Performance on May 29, 2017 20:25:35 GMT -5
I would start by checking the right side control wiring.
Post by thegreatalways on May 29, 2017 20:31:01 GMT -5
Ok how would I go about doing that
Post by FrankenMech on May 29, 2017 23:10:25 GMT -5
First thread here: 49ccscoot.proboards.com/thread/18990/helpFind one of the schematics in the tech section that matches your scoot as close as possible if your scoot did not come with one. Then get a test light or a meter and sort through the kill switch and start button wiring. Tracing the wiring is an educational process you need to go through to maintain your scoot. Scoot wiring is VERY simple. Unfortunately there are many ways to wire those 'simple' functions so you have to figure out which one your scoot uses.
Post by ozo on Jun 7, 2017 17:39:49 GMT -5
Hey fellas my kill switch is not working and my starter button is not working only way for me to shut it off is by putting hand over exhaust it's a tao tao summer Iassume you mean a Tao Tao Zummer not a Tao Tao Summer. I have that same scoot 2015 model. The kill switch assembly has just two screws holding it. Remove the two screws and you will see that the wiring is connected with a connector. One for the kill switch and one for the start switch. Ensure that they are both connected. If they are not loose the next connector is 22" from the switch housing. It is a 5/6 pin connector. Ensure that it is connected. I have not been further into the electrical harness for the kill/start yet. If both start and kill are not working I would think it is that 5 pin connector is disconnected rather than both connectors in the housing. One maybe but not both. Further, if that 5 pin connector is disconnected the brake light when Right lever is depressed will not work either. Check that.
