Post by Bakeman on May 31, 2017 8:54:24 GMT -5
Looking to buy rear gears . Were would the best place to order them from. I wanna stay away from the cheap ones . Thanks in advance .
Post by acvw74 on Jun 1, 2017 19:17:47 GMT -5
I had a set of no-name...and they literally crumbled for 500 miles. Bought a set of HOCA 1000 miles ago...zero issue.
Post by jeff84 on Jun 1, 2017 21:28:39 GMT -5
cant go wrong with polini or malossi either. they are pricy though
Post by Bakeman on Jun 1, 2017 22:16:14 GMT -5
I'll look into the Hoca brand then .thanks
larryhobman
Post by larryhobman on Jun 5, 2017 22:14:20 GMT -5
Do you feel that the gear change is worth doing? Did you get good results? I installed a set and had to do a lot of tuning just to get back to before I installed them. I did not see the benefits and have been thinking of removing them.
Post by Bakeman on Jun 6, 2017 16:25:22 GMT -5
I can try and just see what happens .
Post by tortoise2 on Jun 6, 2017 17:11:15 GMT -5
Might be prudent to use blue thread-locker during re-assembly to avoid this.
