Post by humanshield on Jun 8, 2017 20:42:28 GMT -5
It sure can. The engagement dogs usually go bad. There are usually 3 on it
When the starter clutch on a 150 (for example) is bad you will hear the starter motor turn, but the starter clutch mechanism inside the motor may not engage. The 150's with internal starter clutches are totally different than 50cc starter setups. You have to remove the flywheel and right side engine casing to get to it. a slight PITB
