Post by badluna on Jun 9, 2017 22:20:12 GMT -5
Hi,
Broke my belt. i replaced it and noticed my rollers are shot.
Im thinking about upgrading them to slider. Can and one point me in the right direction>
What size fits? Are the stock rollers 5 grams? And if so should i just buy 6 Gram sliders?
I just want something that will last longer and maybe squeeze out a few MPH.
thanks!
Post by 90GTVert on Jun 10, 2017 8:03:28 GMT -5
16x13mm sliders will fit the stock and most aftermarket variators. I use DrPulley sliders, though some get good results from cheaper brands. Stock weights can vary. They may be 5g. That's what mine had. If choosing only one weight for sliders, I'd go 5g. See how they work. If RPM is too high (sliders are too light), then you can stuff them each with a gram of aluminum foil. You will need a scale to make keeping them all balanced easy. I suppose you could cut all pieces of foil to the exact same size and they should be quite close as well. A scale is only around $10 on eBay or amazon though. 49ccscoot.proboards.com/thread/1199/modding-roller-weights
