Post by V90Performance on Jun 18, 2017 20:37:06 GMT -5
Post by scott7 on Jun 19, 2017 6:57:41 GMT -5
Partsforscooters.com has that kit for 256.99
Post by V90Performance on Jun 19, 2017 7:31:03 GMT -5
Oh nice, thanks for the heads up.
Post by diynuke on Jun 19, 2017 7:36:11 GMT -5
the brand is fine but i am skeptic about how long it will last and a oil cooler seems like a must and the crankshaft is also know to fail quickly when you have such a big bore on there i still wonder why they don't make special crankshafts which have a bit more counterweight because that's where it is all about heavier piston means the crank will be out of balance so the bearings have way more load on them. but yeah brand is fine but you will have to do some more to make it reliable their 72cc kit is great
Post by V90Performance on Jun 19, 2017 7:59:28 GMT -5
Yeah I'll consider the oil cooler. I'll look into the crankshaft. My old scooter had 1000+ miles with the 50mm bbk.
Post by greggkinney on Jun 21, 2017 11:41:58 GMT -5
naraku is good quality but ive heard the head in that kit is kind of nasty. id get a scrappy bvh and a Taiwan made kit over the naraku if it were me. from the 3 bvh's ive bought the scrappys is by far the best
Post by V90Performance on Jun 22, 2017 11:35:22 GMT -5
I'll keep that in consideration. Does the scrappydog have a 52.4mm bvh?
Post by greggkinney on Jun 24, 2017 0:21:57 GMT -5
im not sure the exact diameter of the combustion chamber because the head is on the scoot now. its kicks butt with a 52mm. i bought a kit that came with a head, a glixal head and scrappys. jus by looking at them his blew the others out of the water, but for $25-30 the glixal 47mm bvh is pretty decent and works good with a 52mm bbk and no base gasket
Post by V90Performance on Jun 24, 2017 22:39:34 GMT -5
How many miles do you have with the 52mm? I like the idea of more power with a 52mm but I'm concerned about the reliability. I've had over 1000 miles with my old scooter with the 50mm bbk before I traded in for a wolf V50. I wonder how long can the engine last with the Naraku 52.4mm bbk. I just want to spend good money on a bbk to not worry about it breaking down later on.
Post by greggkinney on Jun 27, 2017 10:27:33 GMT -5
i dont really keep up with miles but i do ride alot of long distance commutes between towns. around 30 miles each way at WOT. ive had the one kit on for a month or so and the other 1 since april but it dont get rode much. try messaging dexameth he has a 52mm with bvh and 150 carb. he's probably cloked more miles than me and rides pretty hard too
Post by fugaziiv on Jun 27, 2017 10:38:33 GMT -5
naraku is good quality but ive heard the head in that kit is kind of nasty. id get a scrappy bvh and a Taiwan made kit over the naraku if it were me. from the 3 bvh's ive bought the scrappys is by far the best Naraku is Taiwanese. Matt
Post by greggkinney on Jun 27, 2017 13:24:42 GMT -5
naraku is good quality but ive heard the head in that kit is kind of nasty. id get a scrappy bvh and a Taiwan made kit over the naraku if it were me. from the 3 bvh's ive bought the scrappys is by far the best Naraku is Taiwanese. Matt yes it is i was meaning one of the cheaper no name taiwanese kits. im not knocking naraku i like there other kits esp. the 47mm, jus not a fan if the bvh that comes with the 52.4mm
Post by fugaziiv on Jun 27, 2017 13:55:02 GMT -5
yes it is i was meaning one of the cheaper no name taiwanese kits. im not knocking naraku i like there other kits esp. the 47mm, jus not a fan if the bvh that comes with the 52.4mm Cool. I didn't take it that way, but I totally get where you're going with your recommendations. Matt
Post by V90Performance on Jun 27, 2017 16:29:27 GMT -5
Alright, I think I'm going to bite the bullet and order the Naraku 52.4mm kit in the following weeks. Thanks everyone for their inputs.
Post by greggkinney on Jun 27, 2017 22:51:39 GMT -5
yes it is i was meaning one of the cheaper no name taiwanese kits. im not knocking naraku i like there other kits esp. the 47mm, jus not a fan if the bvh that comes with the 52.4mm Cool. I didn't take it that way, but I totally get where you're going with your recommendations. Matt are you affiliated with partsforscooters? if so id like to ask you something about a hoca 52mm set up. i was going to contact pfs but if you work there talking to you would be even better😁
