Dogbite
Chinese scooter Hacker
Post by Dogbite on Jul 1, 2017 20:29:13 GMT -5
Check auto enricher with ac volts not dc. It starts dumping gas and it gets about 14.2 volts ac on my bike and shuts off after a few minutes. If you unplug it it will not shut off and will cause surging when warm,because too much raw fuel.
chemi
Post by chemi on Jul 4, 2017 1:41:02 GMT -5
it get around 11-12 volt s
chemi
Post by chemi on Jul 5, 2017 20:44:58 GMT -5
It's definitely running rich,if it's all stock engine your main jet should be about 75 or close to it. I would see what size jet is in it. You said you diconected the air filter and it did the same thing? . You can try and tale out the air restrictions in the air filter and see what happens. Also check your electric choke and your vacuum petcock. They both can cause a rich condition if not operating properly. You can find out how to do all things from the tech library in the website. So I took the carb apart and I found the jet was missing I shook the carb and jet came out I put it on and she runs an goes so that solved my issue
Post by scott7 on Jul 5, 2017 21:28:24 GMT -5
Awesome
chemi
Post by chemi on Jul 5, 2017 23:29:00 GMT -5
i gonna take pics after i run a new spark plug
chemi
Post by chemi on Jul 6, 2017 4:32:07 GMT -5
im just gonna assume this is okay now
Post by scott7 on Jul 7, 2017 6:50:52 GMT -5
That's about the way I run mine. A little on the rich side as long as it's running good
