Post by joeorange on Jul 5, 2017 9:15:07 GMT -5
I was wondering if anyone knew if the Aerox Stage6 Subframe will fit the frames of our chinese scooters with the 1E40QMB?
Post by moofus02 on Jul 5, 2017 11:09:01 GMT -5
Doesn't fit the clones or the Zuma. You have to build your own. I've seen guys take the short case clone mount that was rear facing and use it in a long case clone with a rear stage 6 intake. But that mount has a through bolt that is in the way. They used some pvc pipe and a 45° elbow to get the carb over and behind the bolt. Seemed to work well
Post by joeorange on Jul 9, 2017 22:10:49 GMT -5
well crud, im in need on a new engine mount/hanger for my 1e40qmb engine since i use my old one to build my gy6 swap mount. and the only one i found that was a real good decent price fell through, since the seller didnt take into account of the shippings costs from the uk to canada. and i wasnt going to pay for $150 for a used mount.
Post by hellish100 on Apr 11, 2018 22:13:53 GMT -5
Bringing this thread back from the dead.
Will the stage6 mount fit a horizontal zuma motor or is the aerox different? It’s going on a custom frame anyways so I’m not worried about if it doesn’t bolt to a specific frame.
Post by benji on Apr 12, 2018 0:22:01 GMT -5
I'm pretty sure it's different
Post by spaz12 on Apr 12, 2018 18:13:59 GMT -5
Bringing this thread back from the dead. Will the stage6 mount fit a horizontal zuma motor or is the aerox different? It’s going on a custom frame anyways so I’m not worried about if it doesn’t bolt to a specific frame. It will fit on the motor just fine. It's where it attaches to the frame of the scooter that is the issue. Unless your scooter frame has the same dimensions at the mounting point as the Aerox, then it won't fit. You'd have to ask someone with an Aerox to get that information. Your best bet is to make one yourself from your existing mount.
Post by ThomasTPFL on Apr 12, 2018 21:29:09 GMT -5
I'm confused. Doesn't Stage6 do one for standard Minarelli engines too?
Mine fit fine when I was using the shortcase Jog engine with the jog wheel. The sideways offset was wrong for the longcase with the wider wheel though.
Post by tsimi on Apr 12, 2018 21:57:49 GMT -5
It is not a problem on the engine side more an issue on the scooter frame side. As far I know it doesn't fit the Jog frame or Zuma or BWS frame. Pig took dimensions of one. Check this thread here, 2nd post. 49ccscoot.proboards.com/thread/11174?page=1
Post by ThomasTPFL on Apr 14, 2018 21:54:32 GMT -5
I have no clue what kind of stage6 rear mount I started with. It's in a TGB frame holding a CPI longcase now though.
Post by pete130 on May 22, 2018 3:28:51 GMT -5
I have the mod your wanting to do but on aerox 100 if frame is same as aerox cant see why it wouldnt fit and if you have costom frame you should be able to make fit i would try and see where you stand sorry i know u know it fits aerox motors
